Dvd player between $250-300? Denon dvd910?
Discussion in 'Playback Devices' started by Trevor_O, Oct 8, 2003.
  1. Trevor_O
    Trevor_O Auditioning
    Oct 7, 2003
    3
    I'm just trying to find a good unit between the amount posted above. Its going to be used on a more than likely 27 flat screen sony or toshiba, the tv I get may or may not be hdtv compatible. I was looking at a single disc dvd player with progressive scan. Are there any other options in this price range? I'm mainly looking for good picture and sound quality, sound wise, I'm running through a current Onkyo Tsdx575, I'm using my ps2 as my current dvd player. Any of your help is greatly appreciated!!
    T
  2. Rich Stone
    Rich Stone Stunt Coordinator
    105
    You might try to obtain a recently discontinued Denon 1600. I did the research and ordered one from Crutchfield for around $300 - so far my impressions over the last two weeks have been very favorable.
    Just my two cents. Good luck.
    Rich
  3. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Yeah at the $300 level the Denon DVD-1600 is the best choice! It beats many $1000+ players and of course is much superior to the cheaper players. Hurry it may disappear very soon though.
  4. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    www.ecost.com has the Denon 1600 for $250 refurbished and the Denon 900 for $99 refurbished. They had some refurbished 910s for $88 but the sold out very quickly, but I beleive they are supposed to be receiving some more.
  5. Trevor_O
    Oct 7, 2003
    3
    ok guys I found a couple 1600's for around $300, but have a couple questions. What makes this one so much better than the 910? Also I found a 900 for around $259. Whats the difference between the 910 and 900? Thanks for the replys!
    T
  6. Don_Berg
    May 30, 2003
    931
    The DVD-900 is terrible compared to the 1600. The 900 has terrible frequency response resulting in a very soft image plus it has chroma bugs. The DVD-910 is better than the 900 but it too has a softer image and a color flicker issue due to CSS off compared to the 1600. The 1600 is still superior to all of the others. For a $50 difference the 1600 is a much better buy! The 1600 also has DVD-audio which the 900 and 910 both lack. If you want a model like the Denon 1200 for $250, Tweeter stores carry the Mitsubishi DD-8040 which is the same basic design as the DVD-1200 including DVD-audio. But the Denon 1600 is still the top quality of all of these.
  7. Trevor_O
    Oct 7, 2003
    3
    The truth is I don't know what to look for! I was wanting a dvd player that had great picture and sound for around that price range. I don't really listen to music at home as I'm at school the majority of the day. So the 1600 doesn't have a coaxial digital output? I'm also assuming Onkyo doesn't make a good dvd player in this price range either.
  8. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,771
    14
    610
    Jeremy
    Ill back up the DVD-1600. Great player. Get one while you can.
