DVD Player Audio Quality
Discussion in 'Archived Threads 2001-2004' started by Gary TP, Sep 26, 2002.
  1. Gary TP
    Gary TP Stunt Coordinator
    Sep 11, 2002
    53
    I am looking at the sub-200 dollar range DVD
    which includes the Tosh sd4800 and the Panasonic rp62 or rp82...
    Which one has the best audio output? I will be using this as my cd player as well as dvd player and prob will connect it optically...
  2. John Geelan
    John Geelan Screenwriter
    Oct 11, 2000
    1,087
    I would say the Panny. Though I have a Sony 775 SACD player that I use to play regular cds, my Panasonic RP91 sounds fine with cds too.
  3. Paul Campbell
    Feb 20, 2002
    39
    I don't know from first hand experience, but at that price I wouldn't think there would really be a difference. But I would also probably get the panasonic because their lower-end stuff seems to be built better than Toshiba's.
  4. Mike Likens
    Mike Likens Stunt Coordinator
    Jul 9, 1999
    91
    If you are going to connect the player using its digital output then the sound quality of the player is irrelevant. The sound quality will come from your processor and amps. Using the analog outputs on your DVD player will result in different quality from different players.
