DVD Player as a Pre-amp
Discussion in 'Archived Threads 2001-2004' started by anth_c, Dec 17, 2002.
  1. anth_c
    anth_c Stunt Coordinator
    Jul 17, 2002
    79
    I have a older Dolby Pro-Logic Receiver that only has a 2 channel input. In addition to the receiver, I have a multi-channel amp. Before I buy a new controller, is it possible to run the multi-channel outputs from a DVD player to the multi-channel amp so that I can get 5.1 sound from this current setup?
    Anthony
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    No, I'm afraid that wont work.
    Consider this: how will you adjust the volume?
    The DVD player also does not know if your speakers are LARGE vs SMALL. Your receiver does some bass-management that your DVD player does not.
    The 6 analog outputs on the DVD player are designed to run through a processor before the amp to handle these and other issues.
