ChristopherDAC
- Feb 18, 2004
- AE5VI
Mr. Klein:
I believe, actually, that the DVNR is applied to the recomosited video as well as the S output, though I am not sure. In any case, the reason for the recompositing would stand to reason to be that the Y/C separation is performed together with the digital timebase correction and dropout compensation; since all these operations require a memory circuit, it only makes sense to integrate them. Now, if you are absolutely sure that your display's comb filter is of a higher grade than that in your player, it does make sense to try the composite output, since [at least with the DVNR off] the imperfectly separated chroma may be mixed back in by a basically transparent process, so that the actual chroma can be separated out again and cross-colour and cross-luminance artefacts avoided.
In any case, I like to depress a little button on the front of my 704 when I turn it on, marked "DVNR OFF". This cuts out all processing except the necessary, so that the eventual output signal is as close to "raw" as possible. For better than that, I guess you would need an industrial LD-V8000.
Mr. Boulet:
While my current viewing environment is such that my display choices are normally a small 4:3 television at several screen heights distance or a computer monitor uncomfortably close up, my judgements are based on extensive viewing of LDs and DVDs on various apparatus, including projectors [LCD and DLP, but sadly not CRT to any great extent] of 4:3 and 16:9 native ratios. I am looking into picking up an older DLP video projection unit for use as a secondary computer monitor and video display. Players I ordinarily use for LD are the CLD-D704 and an old Karaoke machine called a CLD-V710; I have seen various DVD reproducing mechanisms, but most of my DVD viewing time has been spent with HTPCs of various ilks.
I should point out, for purposes of clarification, that most of the programme material I am interested [back catalogue anime titles, primarily] in is 4:3 in the first place, and in many cases it was transferred to and even edited on composite video [1" C-type or sometimes D-2], and no other master exists. Additionally, this is a category of DVDs which [when available at all -- many titles remain unreleased] is typically overcompressed and suffers from poor mastering choices, not least because the MPEG encoding system is not intended for this type of film. My viewing experience has, however, been considerably wider than just this narrow area of specialisation -- I merely feel the need to confine my almost illimitable concupiscence within some bounds which will help stop me ruining myself.
Anyway, the individual's experience will vary. As I say, I certainly notice the NTSC artefacts; only very rarely, though, do I find them annoying. It is much more frequent that I am disturbed by MPEG artefacts, and in some cases they literally make my skin crawl [my most common complaint has got to be the moire pattern which lossy DCT imposes on any flat-colour surface, and these washes are prevalent in anime far beyond their occurence in normal films -- at high compression ratios this can get very strong indeed].
Anyway, I do think it's fair to say that DVD's advantage over LaserDisc is its form factor, since most of the people who bought into DVD were moving up from VHS. They could have had the advantages of durability, random access, multiple audio programmes with surround sound, and improved video quality any time in the previous twenty years, but the large size of LD [and, of course, the accompanying higher costs -- not so much of pressing but of handling, storage, and so forth, which also made them less attractive to retail and rental outlets] deterred them.
Mr. Boulet:
