DVD & HD1080i calibration same??
Discussion in 'Displays' started by Mike_Skill, Mar 26, 2004.
  1. Mike_Skill
    Mike_Skill Stunt Coordinator
    Jun 20, 2000
    69
    What's the rule of thumb? I have a Toshiba 56H80, and just got HD sat & OTA. I had my set calibrated by ISF guys two years ago so grey-scale color temp etc accurate for DVD. Should these also be correct for 1080i??
    Also, my convergence goes batty when switching to 1080i. Will this continue?? I remember when the set was new it took awhile for the convergence to hold.
    Thanks much in advance!!
    -Mike
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,373
    32
    New England
    Gregg Loewen
    hi
    the gray scale is universal. however it is sometimes magenta in HD so I use an offset specifically for HD. HD also has a separate convergence. Front panel controls are different between DVD and HD also.
    To do a thorough toshiba calibration you need to have access to the ADDR and Designer codes. These are only available if the calibrator signs a NDA with Toshiba.
    Regards
    gregg
  3. Mike_Skill
    Jun 20, 2000
    69
    Thanks Gregg!
    -M
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    You will find that HD is usually very close to what the DVD was set at ...
    Regards
