DVD Changer? SonyDVP-NC655P or Onkyo DV-CP500
Discussion in 'Archived Threads 2001-2004' started by EdL, Sep 9, 2002.
  1. EdL
    EdL Auditioning
    Nov 5, 1999
    7
    Okay folks I need some help. The Sony NC665P or the Onkyo CP500, both are progressive scan which I need for my Mits WS-55807. I also plan to use it for music. The Onkyo has 192/24 DAC's vs 96/24 for the Sony. Both are new and not in stock (wait until 9/28) or in the same show room so I can't do a head to head comparison. My primary objective is video then audio.
    The Sony has a 27 MHZ/12-Bit Video D/A Converter & the Onkyo a 27/10 video converter which makes me think the Sony has a better picture. The Sony has a higher video dynamic range 103db vs 95db, as well as a higher video S/N ratio 115db vs 90db for the Onkyo.
    I have a Onkyo TX-SR700, of which I am very satisfied.
  2. Lee Petty
    Lee Petty Stunt Coordinator
    Jun 1, 2002
    204
    personally i would go with the sony because of the advantages you listed above, not to metion the $70 price difference.
  3. Asa_M
    Asa_M Auditioning
    Sep 11, 2002
    6
    hey, i would like to get some responses also ...i am looking at getting the onkyo
    i never base decisions on specs because most are wrong and misleading
    has anyone ab'd these?
  4. Phil L
    Phil L Supporting Actor
    Dec 27, 1998
    782
    You might want to consider throwing the panasonic cp-72 into the mix- no chroma bug.
  5. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Ed, you will have to compare the Sony and Onkyo units side-by-side. The specs. on paper don't tell the whole story. Implementation is key. A 24/192 DAC means nothing when we are talking about a player that does not play DVD-Audio discs. In short, there is no 24/192 material out there that the Onkyo changer can decode. Similarly, I would not make any assumptions regarding video DACs. Also, Onkyo is known to be conservative with specs., so don't read too much into that low signal-to-noise ratio.
  6. EdL
    EdL Auditioning
    Nov 5, 1999
    7
    I broke down & got the Sony. I'll be putting it through it's paces this weekend. I really wish I could do a side by side. I am giving some thought to buying the Onkyo when the store has inventory & doing an A/B comparison. My wife will think I'm crazy. I'll let you all know the weekend.
    As far as the chroma bug goes, for me ignorance is bliss. If I don't know what to look for, I may never notice it.
  7. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    EDL,
