ron feinberg
- Oct 15, 2003
For Christmas, I purchased my wife a basic DVD player to hook up to her bedroom TV. The TV is a 13" tube style, integrated VHS, fairly recent basic model. It has basic audio/video RCA jacks on its own input. So, it all hooks up rather obviously and without problems. I turn the TV on, switch the TV to that external input, start the DVD...and I can see the DVD play just fine.
Here's the problem. While the DVD is playing, the picture "modulates" slowly between a bright and dark image. You can see this pattern obviously, as the image shines bright, then slowly darkens, then slowly brightens, etc....
This only happens while a DVD is playing. Not while watching Cable TV, or the integrated VHS player. I've now tried several different DVD players connected to those inputs, and always the same thing. So it's not the player....it's clearly the TV's ability to accept a DVD signal. I even tried connecting the DVD through an FM Modulater unit...directly through the cable input, using channel 3, and got the same result. For some reason, the TV cannot seem to work well with an external input.
Any suggestions? Does this have something to do with Copy Protection signal? Or some video signal modulation? Is some kind of adapter, or signal amplifier, that I should try?
Any assistance would be greatly appreciated.
Ron
Ron
