DeathStar1
- Dec 28, 2001
- Neil
I plan on investing on a DVD Rom Burner sometime this year(Hoping Creative comes out with one since that's the brand I'm familiar with), but I've got a question....
I'm assuming a DVD Burner acts just like a CD Burner as far as creating Audio goes. You drag and drop a wav file onto the DVD, Burn it, pop it into a DVD player, and off it goes.
But here's my question. Do they make car CD players that play DVD Audio discs? This may seem kind of strange, but I create Audio CD's of my favorite TV Shows and movies for listening on long 2 hour Jersey Shore Car trips and other flights. Some of you may have heard Mumm-Ra from Thundercats coming from my car speakers whilst stuck in a traffic jam last year .
But the problem is, the new car has no tape deck, so I've been stuck using regular CDr's. With tape, you can fit 6 eps per tape, but with CDR, it's more like 3.5, wich means twice the amount of CD's compared to tapes.
I would love to convert all this stuff to DVD audio, where I can probably fit 12 per disc, but it's not worth investing into if I can't even play it in the car.
Thanks!
Thanks!
