DVD-Audio question
Discussion in 'Playback Devices' started by Adam Smasher, Mar 19, 2004.
  1. Adam Smasher
    Adam Smasher Extra
    Dec 2, 2003
    17
    Is there a way to extract the audio portion of a DVD-A so I can burn to a CD-R.
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Nope. This is one of the main reasons behind DVD-A and SACD: copy protection. Anyway, even if you could extract it you'd have to burn it on a DVD because it would be too much information to hold on a CD.
  3. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    Actually, the copy protection exists only in the digital domain, which is the reason behind the multichannel (analog) outputs on the player and inputs on the receiver. The recording industry wanted protection from people copying the information 'digitally'.
    There is no reason why you cannot grab the 2ch stereo mix from the analog output and send it to a recording device, or for that matter all 6 channel audio outs to a mixing board and mix down your own 2 channels should you have the time or equipment.
  4. oryan_dunn
    oryan_dunn Agent
    Sep 25, 2003
    37
    I was kinda wondering the same thing. I would like to be able to listen to my DVD-A's in the car, but I can't. That is one of the main reasons that I prefer SACD's is that most of the time, they have a cd layer that I can play in my car.
    Ryan
  5. Scott_lb
    Scott_lb Supporting Actor
    Oct 7, 2002
    592
    I've copied the two channel tracks from some of my DVD-A discs to minidisc with no problems.
  6. Adam Smasher
    Adam Smasher Extra
    Dec 2, 2003
    17
    Thanks Guys. I knew there had to be a way. Funny, I have the Denon 2900 and I did not think to re-record from the analod output. Vic
  7. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    So have I, and the results are spectacular.
  8. ScottCHI
    ScottCHI Screenwriter
    Feb 21, 2004
    1,292
    correct me if i'm wrong, but can't the content on dvd-a's ALWAYS be played back NON-hirez via your coax or optical connection?
  9. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    I can play non-copyprotected 96/24 stereo digitally.
    Any (most) players will pass 44/16, 48/24, dts and DD digitally.
  10. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Maybe, or maybe not. If so, it will surely be flagged DO NOT COPY in SCMS so this would only work with a pro CD recorder or a computer.
  11. ScottCHI
    Feb 21, 2004
    1,292
    like philboy and i said. you can play ANY dvd-a as NON-hirez through your digi connection if you set your player up to do it. the NON-hirez is NOT copyright protected, just the hirez.
