dvd audio question
Discussion in 'Beginners, General Questions' started by Matt Weldy, Feb 15, 2004.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    To take advantage of dvd a do I have to use the analog connections or will the digital cable do the job. I would think the digital cable would work because it works with movies. But if I knew for sure I wouldnt be asking. I have the denon dvd 1600 if that make a difference.
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    Yes you need to connect 6 analog outputs from your DVD-a player to the 6 multichannel inputs on your receiver in order to listen to DVD-a or SACD. Both DVD-a and SACD are decoded in the player and the analog signal is sent to the receiver/preamp. Using a digital connection will not reproduce DVD-a/SACD.
  3. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    Frank is right, but let me clarify a bit..........
    The digital connection will not allow you to listen to the HIGH RESOLUTION tracks on dvd-a and sacd.
    With the digital connection, you'll hear the reg. stereo cd tracks on sacd hybrid discs, and the DD/dts tracks on the dvd-a disc.
    You will need the analog connections for the HiRes playback!
    Good luck!
  4. Matt Weldy
    Feb 4, 2002
    335
    so my next question is how expensive of cables do I need to buy?
  5. Frank Zimkas
    Mar 10, 2002
    888
    Matt,
    Get yourself 3 pair of Accoustic Research Interconnects and your good to go. If you really feel the urge to splurge, make sure you keep your receipts and be sure that you can return the high end cables if you don't hear any difference between them and the AR's.
  6. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,679
    648
    Since 2006
    Cameron Yee
    I don't know the particulars with the Denon, but I need to go into a menu for my player to read the CD layer of SACDs.
