dvd audio hookups question
Discussion in 'Archived Threads 2001-2004' started by KevinVM, Nov 3, 2002.
  1. KevinVM
    KevinVM Agent
    May 11, 2002
    25
    I have a toshiba sd-4800 and am wondering about the connections. If I use the 5.1 audio outs, do I still need to use either the coax/optical?
  2. Doug Smith
    Doug Smith Second Unit
    Mar 14, 2002
    335
    3
    You'll need one of the digital outs for the DVD Video. I just bought the same DVD player. Was your background brightness a little too much when watching DVD's? An example would be when you play a widescreen version of a movie the black bars at the top and bottom were quite noticably light on one half. Although it didn't seem to affect the picture, it was annoying. Fortunately there is a brightness control which I hope will take care of the problem. I am running the Toshiba through a Marantz 3200 receiver.
  3. KevinVM
    KevinVM Agent
    May 11, 2002
    25
    If im reading this correctly, you need to use the 5.1 outs to use DVD-A correct? But do you need to also use one of the bitstream/pcm audio out jacks as well? I plan on using the S video to the tv. I havent used it extensively to say anything about the brightness, nothing noticeable when I have used it.
    Kevin
  4. Scott Merryfield
    Dec 16, 1998
    12,308
    1,066
    9,110
    If you only connect the 5.1 analog inputs, you must use the DVD player's built-in decoder and bass management (or lack thereof) for DVD-video playback. If you also connect the player via a digital audio connection (either optical or coaxial), you can use the bass management and Dolby Digital / DTS decoders built into your receiver. Usually, the receiver's decoders and bass management are superior to those in the DVD player.
    You must use the 5.1 analog connections for DVD-Audio, thanks to the paranoia of the recording industry.
  5. Warren Hubbs
    Warren Hubbs Agent
    Aug 27, 2002
    27
    is it the same for sacd?
  6. John Geelan
    John Geelan Screenwriter
    Oct 11, 2000
    1,087
    if you want to hear Multi-Ch SACD then yes you need to use the 5.1 analog outs to the receiver.
  7. KevinVM
    KevinVM Agent
    May 11, 2002
    25
    Thanks for clearing that up, the manual isnt exactly clear on that aspect of it. Just trying to figure out what cables I need to get.
    Kevin
