DVD Audio Connections
Discussion in 'Home Theater Projects' started by Don__C, Feb 23, 2004.
  1. Don__C
    Don__C Extra
    Jan 2, 2004
    21
    My user manual is a little unclear on audio hookup of my JVC DVD. When connecting the Coax Digital to my receiver, do I also connect the standard audio for non-digital DVD's and CD's? Will the player know which is which for varying audio formats, or will I have to make changes in the player's menu?
  2. Nathan Stohler
    Nathan Stohler Second Unit
    Jan 17, 2004
    329
    All DVDs and CDs are digital. All you need is the digital connection, and set your receiver on "auto decode" if it has such a thing. You will want to make sure your player is set to send the digital signal (it should be in the player's menu somewhere).
    Try using it first. If it works with just the digital cable, then you should be fine. Otherwise, you might have to play around with your DVD player's menus.
  3. Don__C
    Don__C Extra
    Jan 2, 2004
    21
    Removed the analog cables and everything works fine. Thanks for the help.
  4. Patrick Larkin
    Patrick Larkin Screenwriter
    May 8, 2001
    1,759
    In the same vein (or possibly similar), is it possible to hook up a single player to a receiver (Denon 1601 I think) and play CDs and DVDs without manually setting Stereo, DD, etc?
    Right now, when I pop a CD in, I have to select DVD from the receiver and then select Stereo from the Surround options. I'd like to select CD and have Stereo already be set.
    My DVD player currently has only digital outputs and a pair of analog outputs but I will be getting a player soon with a 5.1 decoder built in, if it makes a difference.
    Thanks!
  5. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,757
    671
    9,110
    Since 2006
    Cameron Yee
    Patrick, the player's 5.1 decoder would be for DD 5.1 or DTS and would only be used for discs encoded with those formats. If I understand your question correctly, you basically want your receiver to know whether your disc is a CD or DVD or know whether you want to listen in stereo or surround mode. Well, that's quite a lot to ask and I think would require some kind of artificial intelligence feature. Basically the receiver just sees whether the signal is two channels or multi-channel and its up to you to set the listening mode that you prefer and which is compatible. Sometimes you might want to watch a two-channel movie in stereo and forego Pro Logic and another time you might want to listen to a CD in five channel stereo or some other DSP mode. There are just too many preferences and variables for a receiver to figure out what you want. The solution to have CDs always be in stereo mode would be to either get another player dedicated to CDs and run it to its own input on the receiver and leave the setting on stereo, or run another output from player (either analog or the other digital if it has it) to another input and leave that on stereo.
  6. Nathan Stohler
    Jan 17, 2004
    329
    My receiver is set on "auto decode". If there is a DVD in the player, I get DD/dts/etc. If there is a CD, I get PCM, which is played in stereo (plus the sub).
    Your receiver should be able to automatically decode the digital signal.
  7. Patrick Larkin
    May 8, 2001
    1,759
    As I was saying, CD's default to Dolby Pro Logic on my receiver. It makes no distinction between a DVD and a CD. The PLAYER knows the difference...
  8. Cameron Yee
    May 9, 2002
    11,757
    671
    9,110
    Since 2006
    Cameron Yee
    I wish I had more experience with different types of receivers, then I could give a conclusive response. Oh well. This sounds like the receiver defaults to stereo with two channel sources. What happens when you put in a DVD and select a two channel track like the audio commentary or plain Dolby Surround? Does the receiver go to Pro Logic or stereo mode?
  9. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    It’ll work just fine, Patrick. The players output both digital and analog signals simultaneously.
    Wayne A. Pflughaupt
