DVD Album - Storage (1 Viewer)
Does anyone have any idea's on an economical way t create a DVD album like this Case Logic album? I have about 500 dvd's and buying the case logic equates to about 1 dollar per DVD. I'm really looking for some sheet protectors that can hold dvd cover art/inserts.
Any ideas would be appreciated.
Thanks!
Jason
Zane Charron
I don't think there is a reasonable priced solution to storing 500 DVDs, especially if you want them to carry the inserts as well. I have about 300 of my DVDs in case logic CD folders, which works fine (except it tends to scratch the up-side of any dual sided DVDs, though that's usually the P&S side anyway).
TheThrillisgone
