Mike Loiterman
- Jan 24, 2000
Aside from a Rat Shack switch box is there any "hi-end" way to achieve this?
It seems that this is a solid unit. If only I had more cash!Well, you were looking for a high-end solution. You might try the Radio Shack switch boxes before going for a more expensive option. Two of these boxes will run you $30. Try them out! The Radio Shack part number is 15-1952.
