dvd-a 5.1 inputs question
Discussion in 'Archived Threads 2001-2004' started by Sean Patrick, Jun 15, 2002.
  1. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    why won't dvd-audio work properly in the 5.1 pre-inputs in my receiver (HK AVR75)??? They seem to be the same inputs that the newer receivers have. When i plug the 5.1 dvd-a outputs of my RP91 into them, i get the full surrounds but with no control over the volume. is there something i need to set up in the rp91?
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Sean,
    There have been reports that the 5.1 inputs on some of the HK Receivers are passthru, and do not engage the volume control.
    Do a search, and you should see other discussions about this topic.
