DVB318 on a Sanyo HT32744; lockup over DVI/HDMI (1 Viewer)
Matt^K
Hi guys,
I cannot get the DVI-output from the DVB318 to work on the HDMI input on my Sanyo HT32744 at all.
My player has the March 2004 firmware and works over the components, but if I use a DVI-to-HDMI cable or the included DVI-cable with a Monster DVI-to-HDMI adapter, the darn thing locks up right away at the "HELLO" screen and needs to be unplugged.
If I start the player unhooked to the television then plug it in after the player initializes and says "NO DISC", the same thing happens: it immediately freezes and won't respond to input until I pull the power on it.
I emailed Zenith's customer service but given their track record as far as support is concerned, I'm not planning on getting a response anytime soon and my RMA deadline is drawing close. If anybody has any suggestions I would greatly appreciate them.
Thanks!
EricRWem
Adrik
Very stupid question: Did you make sure the component video cables were completely unplugged when you switched to DVI? Call 1-877-9Zenith.
You're not the first I've seen having an HDMI-DVI issue like this.
Matt^K
Yeah, I made sure the components were unplugged.
Thanks for the phone number, I completely glossed over that on Zenith's customer service site. Some guys over at AVS have said that this is a common problem with the HT32744, so it looks like a return and the Denon 1910 is my only option.
If Zenith provides a fix, I'll return and post it.
