Dust Buster Novel Idea
Discussion in 'Archived Threads 2001-2004' started by Zak Solo, Mar 8, 2002.
  1. Zak Solo
    Zak Solo Agent
    Mar 19, 2001
    36
    I recently discovered a solution to all those bits of dust that collect in the various components of my Home Theater.
    Basically I bought a decorators brush (the softer the better) I then used electrical tape to cover all the metal and sharp edges that might scratch anything.
    Use the brush to get into all the cracks/crevices, it works a treat. My system looked brand new after a few minutes. It works on the remote controls and in the corners of the TV screen where dust collects.
    By the way it also works in a car.
  2. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,395
    5,110
    Atlanta, Georgia
    Lee
    Zak,
    Great idea! We use a fine detailers brush for autos here in Atlanta.
    Also, I use Pledge Grab-It Dry Unscented Mits for general dusting. The mits fit the hand well and allow more control. I use these for cleaning my hard to clean 6550 vacuum tubes on the Audio Research Amp.
    [​IMG]
    Lee
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Damn Lee, I didn't know you were using tubes!
