Dune Widescreen DVD (1 Viewer)
Bill Griffith
I recently got Dun (widescreen) on DVD
It say its 2.35:1 Widescreen
I have a 47" Pannasonic 16:9
so I would think this would behave like all my other movies that are widescreen with the same aspect ratio
I leave the TV on Full Screen setting (there are 4 settings, Zoom, Full, Just, and 4:3) and on all my other DVD's it either fills up the screen as it should on the 2.35:1 ratio (Not sure of that ration but its close) or there are small thin lines on the top and bottom (probably about 1" thick)
Well why with this DVD with the TV set to Full and the case and DVD says widescreen 2.35:1, do I have almost 4" on the top and bottom of black line and the image looks somewhat streched. I tried all the setting and the only thing that looks decent is if I go to zoom.
My other movies don't have this problem. Is this a problem anyone else has noticed with this DVD?
Blaine Skerry
DUNE is not enhanced for 16:9 displays.
edit: There is a proper setting on your Panasonic TV for watching unenhanced widescreen movies. I don't know what it is but I'm sure someone can give you the proper information.
nolesrule
Clearwater, FL
Joe Kauffman
The 1.85 and 1.78 ratios should fill up your screen with minimal to no bars. 2.35 should be closer to 2.5 inch bars.
And Blaine is right. Dune is not enhanced for 16:9 TVs so you will need to use the proper Zoom mode for your TV to view it properly.
NHCondon
