Dummy Alert! Adding external amp to Denon AVR-4800
Discussion in 'Archived Threads 2001-2004' started by Bruce Berti, Feb 25, 2003.
  1. Bruce Berti
    Bruce Berti Stunt Coordinator
    Jan 31, 2001
    202
    Recently purchased a Harmon Kardon PA-2000 for the sole purpose of powering two outdoor speakers. I read both damn manuals and am confused on how to hook it up. Also once its hooked up and have the speakers plugged into it what exactly do I have to do on the face of the 4800 to activate it. Also, is there something in the setup menu to "turn on " an external amp. Thanks
  2. Jerry Klawiter
    Jerry Klawiter Screenwriter
    Dec 3, 2000
    1,412
    If I remember correctly the AVR-4800 has a multi room zone two outputs
    Just hook these two preouts to the amp inputs.
  3. Jerry Klawiter
    Dec 3, 2000
    1,412
    Then just enable the multi room function and go with it.[​IMG]
  4. Bruce Berti
    Jan 31, 2001
    202
    I posted this weeks ago and am still having problems. The only thing I can get to work using the external amp throught he outdoor speakers is the tuner in the Denon. What am I missing? I need to attend a class for remedial hometheater people I think.
  5. AustinKW
    AustinKW Stunt Coordinator
    May 30, 2002
    169
    Bruce,
    The "multi-room" feature is an analog pre-amp. This means it can only work on analog fed signals. So, to get your CD player, for example, to feed the outdoor speakers, you would have to run a pair of RCAs from the L/R outputs on your player to a set of RCA inputs on the receiver. You can still feed your main system using digital coax or toslink. It's just the multi-rooms that require analog inputs. Hope this helps.
    Austin
  6. Bruce Berti
    Jan 31, 2001
    202
    Thank you big time Austin!!!
  7. MikeMcGrew
    MikeMcGrew Stunt Coordinator
    Apr 17, 2000
    131
    That's a nice looking setup Bruce. Congrats.
