Dumb question but how do I properly clean off an LCD screen? (1 Viewer)
Michael Allred
MI
Michael
I just got a 27" Sony WS HDTV with an LCD screen and I had used a microfiber cloth to dust it but what about when it actually *needs* to be cleaned? Smoke build-up, whatever. What and how do I clean off the LCD screen?
Jari K
Here´s google-search, you probably find plenty of info there:
"clean + LCD" - Google-haku
I believe there are special "cleaning kits" and such. I use only microfiber cloth to wipe of the dust. Haven´t used any water yet..
Best advice is to teach the kids (own, relatives, etc) NOT to touch the LCD-screen. It´s "nr.1 rule" in my house when it comes to LCD. "Look, but don´t touch" ;) It´s not glass (which you can easily clean).
Clinton McClure
Rocket Science Department
Central Arkansas
Clint
Absolutely DO NOT clean with an ammonia-based cleaner (Windex, etc...). This will damage the outer layer of the screen. I use plain tap water (distilled is preferred) and a damp diaper-soft mocrofiber cloth when necessary.
AceMcSmooth
Justin
Also, if your going to use a liquid (water, or non-alcohol, non-ammonia cleaner) wait for the screen to cool after use, don't clean a warm screen.
Michael Allred
MI
Michael
Ok so basically;
dust it off with a microfiber cloth
clean it with distilled water (I bought a jug that is labelled "distilled" so I would assume that's it) using a microfiber cloth. don't clean until it's cooled off and wait for it to dry completely before turning it back on.
that about it?
Chididdy123
Peter
i would just buy a solution from the manufacturer.. i got a phillips solution for my phjillips lcd
Nophix
Rob Milton
I've found the Unscented Parent's Choice baby wipes from Wal Mart are very similar to the "cleansing clothes" that I bougth costing far more. They are non-detergent, non-perfumed, and very sensitive. Basically it's a very mild soap and distilled water. I usually follow that with a wipe-down with a micro-fiber cloth to wipe off the little smudges so common in a home with young children, and it seems to work great. I haven't noticed any issues with our LCD from it, and I've been doing it almost daily for months. God, having young kids is hard on equipment!
samtbax
