Dumb Newbie question about banana plug usage
Discussion in 'Home Theater Projects' started by cacu, Jun 26, 2003.
  1. cacu
    cacu Stunt Coordinator
    Jun 15, 2003
    80
  2. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    Hi,
    Not sure if I understand what you are trying to connect. The link shows pin connectors. These are designed to connect wires to push-button type spring terminals. Banana plugs are larger and would fit into a five-way binding post.
  3. alan halvorson
    alan halvorson Cinematographer
    Oct 2, 1998
    2,009
    Like James said - these are banana plugs - and darned good ones, too, and cheap.
  4. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    Hey alan.
    Those are what I use for my center channel. I was going to look for a picture for cacu, but did'nt have time, thanx.
    James
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    When you use banana plugs, there is now an additional joint in every connection, from the speaker wire to the plug, as well as from the plug to the terminal or jack. This joint, if not soldered, is one more joint that can oxidize or become loose.
    If you can connect the speaker wires firmly and directly to the terminals without having stray strands of wire pointing elsewhere and possibly causing short circuits, you are better off not using banana plugs.
    Exception, if you disconnect and reconnect things frequently such as when transporting equipment to different sites for gigs, etc., banana plugs are very convenient.
    Video hints:
