dum da da dum dum
Discussion in 'Home Theater Projects' started by Christpher_S, Aug 9, 2004.
  1. Christpher_S
    Christpher_S Stunt Coordinator
    Apr 25, 2004
    54
    I managed to poke a hole in the foam surround of my Shiva sub with a cordless screw driver. What would be the best way to try and repair the damage? All the foam is there and the tear isn't visible without looking real close. I'm sure I could glue it with something but I'm not sure what to try. Would shoe goo be a good choice? I sent Adire an E-Mail asking for suggestions but I'm pretty sure the spam filter at work ate the reply. Any opinions?
    By the way, what difference in performance should I expect with and without the little hole in the foam? The sub sounds pretty darn good but I know it needs to be sealed. Especially since it's in a sealed box.
    Chris
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    I bet a spam filter wouldn't have much effect if you called them on the the phone. :wink:
    There are several ways to patch the surround, but wait for a reply from Adire.....
  3. Christpher_S
    Apr 25, 2004
    54
    Phone? On which OS does that run? Is it freeware or do you have to pay for it?
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,779
    493
    9,110
    A cup and a string might do the trick as well...
  5. dave alan
    dave alan Second Unit
    Aug 30, 2002
    256
    A tear in the surround is equivalent to a serious leak in the sealed box. Also, it probably will get larger if not repaired.
    I wouldn't play it until the repair is made.
    You might wanna ask Kyle Richardson for his opinion on the best patch method, as he's familiar with the driver/surround material. Just a suggestion.
  6. Mitch N
    Mitch N Stunt Coordinator
    May 11, 2004
    74
    I've had good luck with rubber cement and a piece of electrical tape on the backside of the sub. Although some would disagree that rubber cement is too harsh for foam surrounds. I figure I'll only keep the sub for a couple years at best. Some of the guys here much sooner.
  7. Chris Brock
    Chris Brock Second Unit
    Sep 13, 2003
    328
    i have used silicon with success in the past. it seemed to do the job great while still remaining fairly flexable.
  8. Darren_T
    Darren_T Second Unit
    Oct 1, 2001
    494
    I think I remember hearing someone else used a black silicone adhesive. I would think something similar to what is used on passive radiator's when they glue the foam to the MDF board might be sufficient.
