Samuel Des
- Feb 7, 2001
I've just moved into my townhouse, and, over the last month, have noticed black dust accumulating in the kitchen. It is particularly visible because the kitchen colour is off-white. Actually, it's quite shocking. There are two heating vents in the ceiling, so I'm thinking that it might be from the gas heater.
I changed the filter before these symptoms occured. Should I use one of those $20 filters? Or worse, do the ventillation ducts need cleaning? The grills of the ceiling vents appear clean.
