Dual Voice Coil Sub
Discussion in 'Speakers' started by JunoVazquez, Jan 29, 2004.
  1. JunoVazquez
    JunoVazquez Stunt Coordinator
    Nov 11, 2003
    79
    I have 2 JL dual voice coil sub with 4 ohms and I have a question on the ohm wiring setup.
    I have a sub amp that is rated 800W Stereo @ 8 ohms per channel. If I series the subs (daisy chain it) would it be able to handle the right "ohmage"?
  2. TanT
    TanT Stunt Coordinator
    Dec 17, 2002
    135
    Wire the voice coils of each sub in series. That will give you 8ohm. Run each sub on each channel of the amp and you'll be fine.
  3. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    Just make sure you connect them in phase. When wiring speakers in series connect the + side of A to the - side of B then connect the - of A and the + of B to your power amp.
    FYI when you connect two speakers (or voice coils) in series their impedance will add. In this case two 4 ohm drivers become an 8 ohm load. If you would wire them in parallel the impedance would become half, thus two 4 ohm drivers become a 2 ohm load.
  4. JunoVazquez
    Nov 11, 2003
    79
    Thank you very much. I'll let you know if my new project works.
