Dual SVS Subs Setup
Discussion in 'Speakers & Subwoofers' started by Chris Huber, Jul 21, 2006.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
    I've got a 1st gen PC+ right now. I'f bought another PC+ it would be the 3rd gen driver, right? Would there be any issues with running them both on 1 system?
    Also, if I had 2 subs co-located, then do I need to make sure they are set for phase opposite eachother?
  2. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    If you co-locate your subs, you want them to be IN phase. Out of phase would cancel out almost all the bass! Send an email to SVS about the driver differences.
  3. Geoff Gunnell
    Geoff Gunnell Stunt Coordinator
    May 20, 2006
    58
    You can upgrade the driver in your old PC+ to the new 12.3 driver for (if I remember correctly!) $169 +shipping. This is a worthwhile upgrade -- do it even if you don't get another sub.
