Dual SVS owners. I have a question (or four).
Discussion in 'Archived Threads 2001-2004' started by Steve Stogel, Mar 4, 2002.
  1. Steve Stogel
    Steve Stogel Supporting Actor
    Jul 19, 2000
    600
    I've got a few questions. When you go with dual SVS's, do you place them "hip to hip" and right against the wall? I've got a single 31CS, and it's in the corner about 9" from each wall. Could you place them diagonally in a corner, side by side, and each up against one of the walls? How would that affect the sound? Is there a general distance that seems to work best in most corners? Could I ask any more annoying questions...wait, don't answer the last one. Thanks.
    Steve
    P.S. I posted this question in a thread that is all but burried, so I just put it in its own thread. It's not something I've ever seen discussed, and I was just curious as to what people's experiences are with dual SVSubs. I have seen Obi's tower of power, and I think it's pretty awesome. I think perhaps SVS should maybe sell an attachment that would allow for this to be done easily (hint hint). Seems like it could be pretty simple, and I wouldn't mind paying $20-$40 for a similar contraption [​IMG].
  2. SkiingNinja
    SkiingNinja Second Unit
    Aug 14, 2001
    311
    Steve,
    You can do pretty much anything..it all depends on your room. I've tried a few different placments...one in front of the other in the front left corner as seen from the couch; that was nasty...bad bad response...then side by side in that same corner...much much better...response is still kinda ragged, but a nasty 20dB null @ 63Hz was alleviated.
    Next I tried one on either side of my RPTV. I was actually able to get (well EQ in) the flattest response with this configuration. I'm still not sold on it though...the SW:TPM THX intro had more slam in the corner loaded position than spread out position...I'm going to keep experimenting [​IMG]
    S
  3. LarrySkelly
    LarrySkelly Stunt Coordinator
    Jan 9, 2001
    129
    I just re-arranged my room to get the subs back into a corner, and I have to say that I have dramatically more bass than ever before. I must have found the 'sweet spot' in this room, its better than the other corner I had them in. I have them right up against each other, out about 18" from the corner diagonally. I'm using an external xover so I was able to adjust the phase to minimize cancellations with my mains, which I run as large, sub=no, run the main pre-amp out to the xover for the subs.
    I have a pair of 16-46CS's, Samson 700, 8000 cubic foot rectangular room. Much more bass than before. The light sabers in TPM makes my couch vibrate and I don't recall that before. In fact that whole movie makes my furniture dance. I've ordered the driver upgrade so once those are installed it will be downright scary.
  4. Jeff Savage
    Jeff Savage Second Unit
    Aug 21, 2001
    386
    Steve -
    I have three SVS's arranged in a triangle shape in the corner (pic's on my web site). I played around a bit with placement using test tones and the RS meter and this combo seemed to give me the best response. I kept the receiver level the same and the meter in the same location then just noted if the dB readings changed as I moved the subs around. Perhaps you could place your subs in different configurations and do the same thing?
    Also here is a link to a discussion over on the Klipsch forum from someone who took what Obi did to the next step. HornEd's Tower of Power
    Laters,
    Jeff
  5. TedO
    TedO Stunt Coordinator
    Dec 17, 2001
    143
    LarrySkelly,
    Do you have a center or surround speakers?
    I think the way you have your speakers set, the center and surround speakers would also get a full frequence signal and if they could not reproduce it, this would be lost.
    My fronts have a good bass punch down to about 44hz, but when I set the crossover to 80hz and the fronts to small I lose this punch. If I set the fronts to large I loose all the bass below 44hz from the fronts.
    The only solution I can see is to get an outlaw 950 that has a triple crossover so I can set the front crossover at 40hz and the center and surrounds at 80hz. My sub is a 16-46cs+
    TedO
  6. gomez_a
    gomez_a Stunt Coordinator
    Nov 14, 2001
    119
    Jeff.
    3 SVS's? WOW!
  7. Steve Stogel
    Jul 19, 2000
    600
    Thanks for the link, Jeff. Good read, and interesting result. Seven plus foot of SVS Ultra. Yikes. Of course, talking to someone with three SVSs, you've got a very good idea of what it sounds like (maybe even more performance). Thanks again [​IMG].
    Steve
