Dmitry
- Nov 30, 1998
Moderators, if this doesn't seem to fit here please move to the DBS area.
Everybody, please excuse the stupidity of the question
I have a dual LNB dish and two wires running from it. Actually there's a whole bunch of wires coming out of the wall but only two of them are coming from the dish
(I know they should've been clearly marked, but...) I currently only have one receiver hooked up but I was thinking of hooking up a second one. So I decided to find the second LNB wire (or rather check the one I think it is) by plugging it into the receiver instead of the first one. The result — no signal. My question is this — are both LNBs supposed to be easily interchangeable? In other words, does it matter which one I plug in? If the answer is yes, I might have some attic crawling to do
