Dual bookselves instead of Center Channel
Discussion in 'Archived Threads 2001-2004' started by Martin Rendall, Aug 28, 2002.
  1. Martin Rendall
    Martin Rendall Screenwriter
    Dec 5, 2000
    1,043
    How come nobody ever posts about running dual bookshelves instead of a single center channel?
    I can understand the receiver only crowd not doing so, since they only have one center channel amp, but many people here run some form of a separates setup. Specifically, most people here are all for separate amplification.
    Given that CCs are such compromises, why not dual mono bookshelves? Bookshelves can often be placed on the TV as easily as a CC, or they can be stand mounted behind and slightly to the side of the TV. They can also go on stands in front of the TV below.
    The center channel is arguably the most important channel in the whole HT. Almost all the dialog, and 65% of the music and effects end up here. [According to an unattributed source... sorry.]
    Martin.
    EDIT: ARG!!! Can a moderator please correct the spelling of "bookselves" in the title? How embarassing! Thanks!
  2. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    i think one bookshelf speaker would work just as well, if not better than its matching center channel. i don't see the need for two.
  3. Martin Rendall
    Dec 5, 2000
    1,043
    Jason,
    Much like bi-amping, I would expect dual speakers with dual amps to run 6dB louder, allowing for greater headroom and clarity.
    Also, speakers are usually sold in pairs, so why not take advantage of them both?
    I don't believe that cancellation would be an issue at higher frequencies. I would be interested to know if anybody knows otherwise.
    Martin.
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    As long as they are sheilded, It should work just fine.
  5. James Bergeron
    James Bergeron Supporting Actor
    Oct 9, 2001
    831
    Might work but really, 1 single bookshelf that matches your mains will do just fine, why bother with both? If it's because you have to buy 2 why not use the second bookshelf as the surround back in a 6.1 configuration?
    I think the WAF has a lot to do with the centre channel thing.
    I ended up with a Centre (Arguably one of the best Studio CC) I COULD put a bookshelf as I am running Front Projection but really it sounds amazing so I don't see the point now.
