BG Enjoi
- Feb 6, 2007
- Dan Vest
Hey guys this is my first post here. I know this is probably not the right section to post this but I need some help building a sub woofer setup.
Okay so I have a 5.1 system right now and my sub is weak from 50hz+ and my speakers don't start to pick up very well until 70-80hz. I am try to help "fill" that gap with a speaker that can produce sound in that range well. I would like to build a dual 8'' sub woofer setup to accompany my 12'' Polk audio sub. I was thinking of using two Tang Band W8-740C 8" sub woofer's and power them with a Dayton SA240 240W sub woofer amp. If someone could tell me what volume I need for two of these subs that would help me sooo much. The box that I am going to build is going to sit atop my Polk sub and the two 8" subs will "hang" over the sides, and the amp will be mounted on the top of the Polk sub. Sorry it might not make much sense how I am explaining it, I would draw a diagram on my computer but all I have is paint ! If you want me to draw something I can..
The things I need to know are; how good the tang band subs are, and what volume will be required. I think that amp should power the two subs well, and from reviews it seems to be very good. If you all have any information that might help me I would greatly appreciate it!
Dan
P.S. I forgot to mention that I have a Sony STR-DG500. How would I hook up the Dayton amp to my receiver if my sub woofer line off of my Sony receiver is being used. I do have a surround back channel that is free, would I be able to simply hook it up to that channel or would the 110 watts blow the amp up? I also have speaker B plugs that are open, its left and right channel. Sorry I am a noob when it comes to amp wiring...
Dan
