Ed B
- Dec 26, 1999
I would like to get a HD based DVR unit to use as a VCR and use it to "tape" shows. I know if I'm not running a TIVO I have to run into the DVR through ch 3, 4 or a line in.
I'm assuming that the DVRs have timers, do they support recording from line in or are they tuner only?
Another assumption, I will have to set 2 timers the DTV and the DVR, is this correct?
I remember way back my old Sony VCR had a device called IR Mouse or something like that. It was a small IR device that you would place near your cable box IR sensor, the other end plugged into the VCR. This allowed the VCR to control the Cable box without needing a tuner of its own. Does anyone know if there is anything like this that still exists?
Other than DTV recording I will be planning on recording lots of old non-commercial VCR tapes (pending my purchase of a VCR lol).
Should I just can the whole DVR route and just get the TIVO but then I wont be able to record my tapes will I?
Ed
Ed
