Dan Galyen
- Jun 10, 2002
I have noticed over the past several months that my receiver or speakers cannot handle a DTS soundtrack. It will run for a while and then without warning enormous distortion comes rambling out of the speakers. It is so bad that I have to stop the disc and switch to DD. I have never had a problem with DD. Funny, though, my Eagles HFO DTS soundtrack runs clear as a bell through the entire concert. Could there be a bitrate issue?
Equipment: H/K AVR (???) receiver
Mirage towers front
JBL center
Eosone rears
New Fisher Prog scan dvd player (had same problem with old Panny dvd player), which leads me to believe it is the receiver.
Any ideas? Should I try coaxial digital connection v. optical and see if there is a difference?
Mirage towers front
JBL center
Eosone rears
