DTS on PC?
Discussion in 'Archived Threads 2001-2004' started by Joshua Wilcox, Aug 18, 2002.
  1. Joshua Wilcox
    Joshua Wilcox Auditioning
    Jun 10, 2002
    7
    I've been lurking around this site for a while, waiting for the day when I have a real income to waste on high end electronics. Until then, I have an excellent setup on my computer. My soundcard has a Dolby 5.1 decoder. Coupled with my surround sound speakers, it is amazing in my small area. I was wondering, however, if I can make my computer DTS compatible. Please be as detailed as possible in your answers because, again, I'm no professional![​IMG] Thanks in advance!
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    PowerDVD can pass DTS through a coax digital in, it will also do a stereo downconversion, but I don't know of any PC card with onboard DTS
  3. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    You might want to consider getting an inexpensive receiver that includes DTS decoding.
    Many modern sound cards (you don't mention which one you have) include a serial digital output (often called S/PDIF = Sony/Philips Digital InterFace) that's compatible with the signal used by most audio equipment.
    Also, at least a couple of companies (JVC and Yamaha, for example) make receivers that have USB inputs.
    I hope this helps a little.
  4. Joshua Wilcox
    Jun 10, 2002
    7
    Sorry, I have a Soundblaster Live! 5.1 and it does have an S/PDIF. I just never knew I could hook that up to a receiver. Thanks for the help!
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I am moving this to the Computers/HTPC area.
  6. Joshua Wilcox
    Jun 10, 2002
    7
    Oh, sorry! I thought my question was a basic one :b
    Anyway, I figured I should ask about this... do you guys know of any cheap receivers that can run DTS and connect to my soundcard? Thanks!
  7. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    Jeff,
    I thought PowerDVD has audio pack that decodes DTS, and presumably, outputs multi-channel audio to your multi-speaker capable sound card.
  8. Chris Brown
    Chris Brown Stunt Coordinator
    Aug 14, 2002
    178
    PowerDVD decoded DTS in software. Just set it to 6 speakers, and it will play fine.
