PaulKH
- Oct 3, 2001
Sorry for the dumb question. I expect the answer is 'no'.
Actually your 7000 would work fine with DTS DVDs it just wouldn't be able tp play the DTS track.
Yes, of course. My answer was limited to DTS tracks.
With most recent releases, it doesn't matter, since dual DD 5.1/DTS releases have become quite common. But the "compatibility track" on the early DTS DVDs was limited to 2.0 (and if it was DD, the 2.0 was a lowly 192kb/ps).
M.
And is DTS audio off CD always 5.1?
All the ones I've heard are. Not much reason to use DTS on CD for anything else (except possibly 5.0, which you sometimes find on DVD as well).
M.
resurrect some of the original old Quadrophonic mixes from the 70s
Ah! That explains why I haven't run across them. Everthing I've acquired is a recent recording or remix.
M.
DTS CD is 20 bit.
So, changing the rate from 44 to 48 khz necessitates changing the bit rate from 1411 to 1536 kbps, but either 16 or 20 bit can reside in the 1411 PCM stream with no alterations in the bit rate required?
Andrew Ballew
I know that DTS audio is 20 bit- no argument. My question is about how the signal is able to fit into the 1411kbps stream at 20 bit
DTS is compressed. It uses perceptual encoding to compress the audio stream to allow it to fit 5 channels of audio in the same space that 2 channels of uncompressed PCM takes up.
It may have been "mastered" at 20/48, but it is on the CD as a raw data stream that is compressed with the DTS codec. It is not true "PCM" as such, but simply uses a PCM header and TOC to fool a regular CD player into passing it on through the digital output.
Actually, there are a lot of 4.0 DTS CDs, I have at least three of them. One of the first thing that the DTS CD producers did when the format came out was to resurrect some of the original old Quadrophonic mixes from the 70s. I have the two Paul McCartney Quad DTS CDs (and I love them) and the Beck, Bogert, & Apice DTS Quadrophonic disc.
Not quite, the DTS CDs DO use the 70s quad mixes, however, there IS a center channel track---the phantom center from the quad mixes has been repurposed in the center channel. This is explained in the tech notes in the CD (at least it was in the original HDS Brad Miller versions---I don't know if it is stillin the new DTS reissues in the new packaging.
As far as I know, the only place to find original FOUR channel original quad mixes is in the new EMI DVD-A classical releases (which states that they are 4.0), and on CBS' SACD surround discs that are reissues of 70's quads, such as Blow By Blow.
I very much like the reusing of the old quad mixes (weird as some of them may have been), as I am finally getting to hear my old quad albums the right way after only 25 years!
