Hi I'm running a simple Sony setup. Here's a link to it on bestbuy.
http://www.bestbuy.com/detail.asp?e=...=1552&scat=242
Anyway, I'm using a cheapo Oritron DVD player that I got back in 2000 for 100 bucks.
Now I know I'm not running a high calibur system by any means, but it sounds cool to me.
My problem is that when I play DTS enabled dvds sometimes especially after I skip scenes, it will have about half to a second of lag in the audio. Meaning the mouth of the actors will run a little bit ahead of where the audio should meet up with it. If I pause the dvd for a second or two, then hit play the problem clears up. Sometimes I get this problem when the layer changes on the dvd.
Is this from my dvd player, or is it something to do with my receiver? My bet is its on the dvd player itself....
Is this normal with cheap dvd players? Oh and yes my dvd player is DTS ready.
