DTS ES & DTS ES 6.1 Discrete
Discussion in 'Archived Threads 2001-2004' started by Darren_Fu, Jun 16, 2002.
  1. Darren_Fu
    Darren_Fu Stunt Coordinator
    Jun 7, 2002
    77
    I am sure this question is stupid but I am curious....Is DTS ES and DTS ES 6.1 Discrete compatible with any A/V Receiver that has a DTS Decoder? Just wondering
    Darren
  2. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,344
    110
    Adam
    Yes. Both are fully compatible with any conventional DTS decoder.
    They are simply replayed as conventional 5.1-channel soundtracks in non-ES DTS systems.
    Adam
  3. Darren_Fu
    Jun 7, 2002
    77
    I have a 6.1 channel receiver. Will it still only be standard DTS? Do you specifically have to have a reciever that says DTS ES compatible?
    Darren
  4. JJR512
    JJR512 Supporting Actor
    Dec 11, 1999
    619
    Justin J. Rebbert
    What's the difference between DTS ES and DTS ES 6.1? If it's that DTS ES is 5.1, then my question would be what's the difference between DTS and DTS ES.
  5. KlausWinkler
    KlausWinkler Agent
    Oct 8, 2001
    36
    DTS ES is available in two variants
    DTS ES Matrix, which encodes the rear center into the two rear surrounds
    DTS ES discrete, has the rear center encoded as a discrete channel
  6. JJR512
    Dec 11, 1999
    619
    Justin J. Rebbert
    In that case, I'd like to know the differences between:
    DTS
    DTS ES
    DTS ES Matrix
    DTS ES Discrete
    DTS ES 6.1
  7. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    DTS - 5.1
    DTS ES - generic - may be either matrix or discrete
    Matrix & Discrete were answered in the post prior to yours by Klaus.
    6.1 can be either also, it depends.
    They are all variants of the same thing, basically.
  8. Dave Moritz
    Dave Moritz Lead Actor
    Jul 7, 2001
    6,956
    1,069
    9,110
    California
    Dave Moritz
    To Darren_Fu
    As far as I know, yes DTS-ES will play on a standard DTS 5.1 system. I have a Yamaha RV-X995 DD/DTS 5.1 receiver that has no problems playing DTS-ES or DD-EX material. To my knowledge DTS is 5.1, DTS-ES Matrixed is 5.1 that blends the two rear stereo channels to mimic 6.1 using 5.1 material, then DTS-ES or DTS-ES discreate is 6.1 material with 6 seperate channels.
    As Far as Logic 7 goes I have not had the oprotunity to really give it a listen. How does it really compare to DPL or even the new DPL2 that Dolby Labs is shoving down peoples throwts? I see that Harman Kardon has Logic 7 in there receivers but I am not sure that the HK can really compete overall with the Denon 5803 or the Pioneer 49TX ??
  9. Michael Reuben
    Michael Reuben Director
    Feb 12, 1998
    21,763
    3
    5,110
    Michael Reuben
  10. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Yes, I would tend to believe that "6.1" refers to discrete also, but as you noted Ruben, I have seen it applied to MANY new 6.1 receivers., regardless of their capabilities. That's all I meant.
  11. Lyle_JP
    Lyle_JP Screenwriter
    Oct 5, 2000
    1,009
    3
    It's also worth noting that DTS-ES Discrete 6.1 isn't 100% discrete either. Yes, there are 6.1 channels of discrete audio to start with, but since DTS-ES tracks must be backwards compatible with standard DTS decoders, the rear surround channel must also be present in the left and right surround channels. A DTS-ES decoder must then use matrixing to remove the center rear channel info from the left and right rear. Therefore, even DTS-ES Discrete must use some matrixing and is not, by definition, a true 6.1 discrete format.
    -Lyle J.P.
  12. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Very true Lyle, but so far from my experience the difference between 5.1 EX/ES and 6.1 ES is pretty great.
    The de-matrix algorithm that extracts the duplicated and unnecessary sounds from the left & right side surrounds (which is replaced by the fully discrete back channel in DTS-ES Discrete 6.1 mode) seems to do a bang up job.
    As one example, listening to the 6.1 ES remix of Rush Hour 2 they actually have spread the instruments from the score to all 6 discrete main channels (the .1 sub channel I'm not including in this discussion) and there seems to be no discernable trace of the back channel sounds also in the side surrounds.
    Yes, a 100% non-backwards compatible 6.1 or 7.1 discrete system would be the best. We can only hope this is implemented in the near future using PCM or DSD encoding instead of lossy compressed DTS or Dolby Digital.
    Dan
