DTS and LFE channel
Discussion in 'Archived Threads 2001-2004' started by Mike Ci, Jan 1, 2002.
  1. Mike Ci
    Mike Ci Auditioning
    Dec 10, 2001
    4
    Do all titles that are encoded in DTS have a dedicated
    LFE channel ? Its seems that my receiver(Nakamichi AV-10) indicates the LFE channel for Dolby Digital 5.1 and
    not for DTS.
    I have tried several disks both DTS CDs and DVDs and
    seems that the sub is producing the effects. I have
    compared the two formats and it seems very similiar
    however the DTS does seem a few dB higher.
    Any confirmed DTS tracks or titles (CD or DVD)with LFE
    would be appreciated. If anyone with a Nak receiver
    would confirm this would also be a great help.
  2. Anthony Stephan
    Anthony Stephan Stunt Coordinator
    Mar 6, 2000
    95
    Try these discs on dts:
    Saving Private Ryan
    U571
    The Haunting
    Appolo 13
    They they don't rock your world, something is wrong.
    I find that the LFE in dts is usually stronger.
    I can't explain why your receiver does not display the LFE, not being familiar with the unit.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    More titles with great DTS tracks that should be tried:
    Gladiator
    Toy Story II
    Titan AE
    T2:Ultimate Edition
    Jurassic Park 3
    [​IMG]
    I also find that LFE is more potent with DTS vs DD.
  4. Tom Weeks
    Tom Weeks Stunt Coordinator
    Aug 23, 2001
    73
    I believe that in order to receive dts you must connect either a digital optical or co-axial cable from back of the dvd player to the back of your receiver. Also you must go into the dvd player's menu and enable the bitstream. Hope this helps.
  5. Mike Ci
    Mike Ci Auditioning
    Dec 10, 2001
    4
    I have connected the digital inputs as per the manual
    I was hoping for confirmation from any Nak AV -10 owners to verify the indication.
    It seems that even though the indication does not show
    a LFE channel with DTS, it seems to produce the effects.
    I have had no response from the Nakamichi Service (emails)
    I just wondering if it is worth a trip back to the dealer
    for service.
  6. Jon D
    Jon D Stunt Coordinator
    Sep 29, 2000
    166
    Make sure that your receiver is producing the DTS LFE (through direct comparrision of DD and DTS tracks). If it is producing the signal, then your display is just messed up. Not a big deal. Try Titan AE or U-571. The DTS LFE on these discs is extremely strong and will instantly show whether your getting it or not. P.S. Toy Story II is Dolby Digital only. If the signal isn't getting through, check your DTS LFE trim, if available. You may have it turned off.
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Oops. Sorry on the TS-II being DD-EX, not DTS, but it sounds so good [​IMG]
  8. Mike Ci
    Mike Ci Auditioning
    Dec 10, 2001
    4
    Thanks for the suggestions hoping to get in touch
    with any NAK AV-10 owners to confirm.
