tom hangler
Grip
- Jan 8, 2003
Hello all,
I have just bought a new home, and it's pre-wired with RG6 cable for tv.
However, since I really dislike digital cable, I elected to purchase DirecTV
Anyway, the installer is coming out tomorrow, and instead of running new wire from the dish to the receivers (2), I'm wondering if I might suggest to him to use some of the existing wiring...
Would this make his job easier or more difficult?
Also, all the wall jacks have a combo phone/data/cable connected faceplate... so if he uses the existing cable feed, would I be able to simply hook up the DSS receivers to the existing cable plug?
Thanks!
Thanks!
