Kris Niesen
- Mar 9, 2003
I'll use DScaler 4.1.6 for a while and it gives much better video than the software included with the capture card.
But there is a strange thing. Maybe someone knows what I can do about it.
Hardware:
* AMD Athlon XP 2000+ processor running at 1800 Mhz
* MSI KT3 Ultra 2 motherboard (MS-6380E)
* Hauppauge WinTV PCI capture card
* Hercules Prophet 3D 9000 Pro 128 Mb (ATI Radeon chipset) videocard
* 512 MB Ram
I use the temporal noise filter set to 50.
I use auto pulldown, auto video detection and judder termination
Besides this configuration (I have tried many settings in DScaler on and off) I always can detect the following artifact:
When there is a horizontal movement from camera viewpoint (left to right or otherwise - f.e. football match) the TV image picture is too slow and blurry. No natural movement in my opinion. With vertical movement (f.e. at the end of a movie) it's OK.
What is the cause?
* A faulty setting in DScaler
* A faulty setting in my control panel for my videocard
* just a bad video card
* bad capture card
* to slow processor
* normal behavior
* something else
I like to here some comment here.
Thanks already
Hardware:
* 512 MB Ram
What is the cause?
* bad capture card
* to slow processor
* normal behavior
* something else
Thanks already
