Keith M.
- Apr 1, 1999
Well, the contractors said they are finished drywalling my theater...
Looks pretty messy in there!! I have to clean all the dried plaster on the floors/cutouts/lights and throw all the scraps out...
They did a good job as far as I can tell, just very messy!!
What drywall primer/sealer should I use before actually painting?
Should I go ahead and hang the door before trim work and carpet or after?
