Driver recommendation
Discussion in 'Archived Threads 2001-2004' started by Rob*Gallo, Mar 9, 2003.
  1. Rob*Gallo
    Rob*Gallo Agent
    Dec 28, 2002
    32
    Not sure if I'm in the right place here...
    A friend has an old (30 years?) pair of Infinity speakers and the foam portion of the 12" woofers have rotted. The cabinets are still in great shape so he would like to keep them. Can anyone recommend a good replacement driver? Is PartsExpress a good source?
    Thanks...
  2. Jonathan T
    Jonathan T Second Unit
    Nov 6, 2002
    360
    Contact the company, see if they still sell the woofers that go with those speakers. If not, then it will probably be completely impossible to find a woofer that is of the exact same specs as the rotten one. Those cabinets, and crossovers were designed specificly for the rotten woofers, so, you would need to find another woofer that is exactly the same as the one you need to replace.
  3. Rob*Gallo
    Rob*Gallo Agent
    Dec 28, 2002
    32
    Thanks! If they don't make the same woofers anymore, is it better to just buy new speakers?
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Using new woofers means building a new crossover. Just get the drivers reconed/refoamed
    http://www.newfoam.com/ offers good service if you're on the east coast. http://www.speakerrepair.com/ is good if you're on the west coast.
    Do a google search for other places
  5. Jonathan T
    Nov 6, 2002
    360
    O man, I wish I had known about that place earler.
  6. Rob*Gallo
    Rob*Gallo Agent
    Dec 28, 2002
    32
    Thanks for the help!
  7. John Wes
    John Wes Stunt Coordinator
    Nov 23, 2002
    202
    www.partsexpress.com sells kits to fix almost any foam surround on woofers...
    I found an ad in an old Stereo Review about 9 years ago ago..and my Marantz HD 88's were biting the dust...I figured why not and ordered a pair..They are still going strong..
    I've done more than a dozen pairs for myself and friends. It's really pretty easy.
  8. Jonathan T
    Nov 6, 2002
    360
    I wish I had known before I tore up the spider on the woofer from an old pair of Ohmn speakers.[​IMG]
