Drive Image, anyone using it on their PC? (1 Viewer)
Frank_S
I have Windows 95 OS on a computer I've had for several years with Applications software on it that I can no longer reload should my hard-drive fail.
I have a Jazz drive in my system so could I clone everything (using Drive Image) including applications from my C: drive to my Jazz drive and then restore it to a new hard-drive with all apps. and data functioning? :)
Could I run everything from my Jazz drive if I did'nt replace the defective harddrive?, that would be even better actually. Thanks in advance. :)
NickSo
Nick So
I really doubt you could boot off a Jaz drive, and I don't think that the Jaz drive is fast enough to run programs and an OS off of...
Travis Olson
Travis Olson
I did it off a Zip Drive once, granted I was running the OS bare bones without a single program running, it was ungodly slow. I managed to play Solitaire though. :D
SteveMc
I am more familiar with norton's Ghost, but it works basically the same. When you image a drive it compresses (usually) the data into one file. So if you did this and stored it on a Jaz disk, you would have to restore it to a HD in order to use it. I think there are some programs out there that simulates a CD-ROM as a hard drive and you can run an OS off that, but i am not totally sure on that one.
Frank_S
I have a SCSI setup so the Jazz drive runs quite fast. I have system commander loaded which partitions my hard-drive into 2 partitions. I still run Windows 3.1 for old DOS programs I have as well as Windows 95 on the 2nd partition. I can also boot to my floppy drive from the System Commander prompt.
Norton Ghost does'nt offer a Windows 95 package so that's out of the question. I also read a lot of negative reviews on Ghost so I think I want to stay clear of it anyway.
Thom B
I'm using DriveImage on ~ 20 lab machines here at work, and it should work well for backing up and restoring to a new drive.
Running off a Jazz drive, scsi or not, will cause something of a perf hit.
Another option to consider. Make a bootable CDR with the HD image and DriveImage sw on it. In the autoexec file you can set up a script to auto-restore when you boot from the CD. Drop me an email if you want assitance with the scripting.
T
KeithAP
Sacramento
Keith
Hi Frank,
I have Drive Image version 1.0, complete retail package, that has been sitting in my closet forever. It is the CD ROM version so it requires a CD drive.
The system requirements on the box indicate Win 95, Win 3.x, NT, DOS or OS/2. Intel 386 SX compatible or higher. 8MB of RAM (16MB recommended for FAT32 or NTFS). CD ROM drive, 5MB of disk space, VGA or better.
Anyway, I will sell it for $10 shipped USPS Priority Mail. FWIW, on the back of the box it says "Store the image file on a second hard drive, JAZ or Zip Drive, CD-ROM, etc.
If you are interested, drop me an email.
-Keith
RAR
