Drilling Into Speakers
Discussion in 'Archived Threads 2001-2004' started by JulioL, Mar 22, 2002.
  1. JulioL
    JulioL Auditioning
    Feb 23, 2002
    13
    I recently got the Energy Take 5 speaker system. I need to set up speaker stands for my two main speakers. I bought these fairly cheap speaker stands from a furniture store here in Los Angeles, Ikea and the instructions indicate that I'll need to drill 4 small holes at the base of the speakers.
    Is there any risk of damaging the speakers?
  2. Chad Isaacs
    Chad Isaacs Supporting Actor
    Feb 20, 2000
    757
    Damage the actual drivers,probably not.Just use a short sharp bit and short screws.Now,if you want to sell them down the road,you might have a hard time.Why not just use some industrial velcro...it worked well for me in a simmilar situation.
  3. Larry Rasmussen
    Dec 6, 2001
    28
    I have drilled into speakers a time or two. Just make sure you put a piece of tape on the bit to use as a reference mark to only go about 3/4 of the way through the wall of the speaker.
    That said, I would think you absolutely don't have to follow those instructions. Use some blue tak or one square of ribbon caulking in each corner of the speaker to fix them to the stands. That's the most common way to affix speakers to stands and it works great. They are stable, won't knock off but you can still pry them up with little effort. Ribbon caulk is sold in any hardware store.
  4. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
  5. JulioL
    JulioL Auditioning
    Feb 23, 2002
    13
    I like the idea of the Blu Tack. Anyone know where I can find it other than the site previously mentioned? I checked my local Home Depot in Los Angeles and they didn't carry it.
  6. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
    Stores like Target have a yellow variant. Its the same as blu-tac cept its yellow.
