Chris Tsutsui
- Feb 1, 2002
Dresser Tempest
Behold, the unveiling of a waf friendly subwoofer. These are pics of it nearly finished. The drawers will be added tomorrow along with the hardware.
Before you go on critiquing the design, the only decision making I had was the degree of curving at the bottom, and choice of molding. The dimensions, and wood were dictated, as were the drawer and panel sizing. The buyer's wife basically designed the whole thing to match her existing maple entertainment center in the master bedroom.
It is a classic 194L 18.4hz Tempest which was first built separately in a 3/4" MDF box. The dresser panels were then attached to that subwoofer therefore disguising it as a dresser. Assembly involved the use of brads, pocket screws, yellow glue, and staples.
It will have a 250W parts express plate amp mounted on the back so the HS fins don't protrude. It will be corner placed in a bedroom home theater. The bedroom Home theater consists of GR-Research AV-1+ speakers, and a Kenwood VR-5080.
I also redesigned that site so feel free to check it out and let me know if anything doesn't work or look right. It's still in the "beta" stages.
