AllanW
Grip
- Nov 2, 2000
What new receivers that decode using DPLII offer the optional "Width", "Dimension" and "Panorama" parameter adjustments.
I am pretty sure the new Denons (2802, 3802) offer this, but does anyone know if the other manufactures are offering these adjustments.
Here is some info on these settings:
PL II offers two different decoding modes: Music and Movie. With PL II Music, there are 3 optional parameters: Dimension, Panorama, and Width.
Dimension is used to adjust the front-to-rear balance in the room. The adjustment has 7 possible positions. The default position is 0 which has the balance equal. A setting of +3 puts the balance toward the front of the room and a setting of -3 puts the balance to the back of the room.
Panorama is used to wrap the sound field around you. You have two options, On or Off. The default is Off.
Width is a center spread adjustment. The default value is 3. A setting of 0 sends most of the information to the center channel, and a setting of 7 is full left and right only. This provides a phantom center image.
Allan
Allan
