DPL12 question for Jack G
Discussion in 'Archived Threads 2001-2004' started by Stephen Dodds, Jan 23, 2003.
  1. Stephen Dodds
    Stephen Dodds Second Unit
    Aug 29, 1998
    354
    I've noticed in a couple of posts that you have mentioned leaving one of the coils open on your DPL12s to raise the QTC, with EQ advantages
    At the moment I have the coils on mine in parallel, and then the two drivers in parallel., per side.
    What is the advantage of leaving a coil open given I can actively EQ, if any? And do you just mean not connecting he wire?
    Cheers
    Steve
  2. Stephen Dodds
    Aug 29, 1998
    354
    Thanks. I did some experimenting and it might just be easier to wire the coil in series and then parallel to the amp. It appears I have headroom to spare.
    One of other question though, are you having any problems with lead slap?
    Steve
