DPL II Question
Discussion in 'Archived Threads 2001-2004' started by Bill_Mazz, Sep 6, 2001.
  1. Bill_Mazz
    Bill_Mazz Auditioning
    Feb 26, 2001
    7
    Does anyone who has DPL II notice any improvement in dialog clarity? I have a Yamaha 995 and none of the DSP modes including Yamaha's enhanced prologic seem to help with dialog clarity. I sometimes have trouble understanding dialog in action oriented programs like Farscape and X-files where the characters speak softly while all is exploding about them unless I turn up the volume. I don't have this problem with DTS/Dolby Digital sources but almost all TV programming is at best Dolby Pro Logic.
    I have Klipsch speakers which while bright are known for clarity so I am considering updating my receiver or adding a DPL II external decoder (if such a thing exists).
  2. Robert Ma
    Robert Ma Second Unit
    Jun 18, 2001
    368
    Are your channels speaker level properly calibrated? You may need to boost your center channel up a little. This will help dialog
    Goto www.erols.com/rmahle to see my theater
  3. Bill_Mazz
    Feb 26, 2001
    7
    Thanks for the suggestion but my speakers have been calibrated using Yamaha's test tone. The center channel has been set 1 db higher than the other speakers.
    I still notice that at low volumes stereo mode out performs dolby pro logic for dialog clarity. I was wondering if DPL 2 is any better than vanilla prologic or the DSP modes Yamaha provides.
  4. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    Regular DPL has a limited range center channel, so in comparison with regular stereo, dialogue does sound a bit thinner (and perhaps less clear). DPL2, however, has a full range center channel and does sound quite a bit fuller than regular old DPL. Even at low volumes, DPL2 holds up nicely. And unlike DSP modes, DPL2 doesn't add any fakey reverb to the mix.
    Also... calibrating with the receiver's internal tones is often the wrong way to go. I've seen receivers whose tones are off by as much as 5db in the speakers when compared to a calibration disc such as Avia or Video Essentials. In fact, my Onkyo 595's internal tones were off by 2db in the surrounds, 1db in the center and 10db in the sub (yes, I said TEN DECIBELS).
  5. Darren K Price
    Aug 8, 2001
    23
    So even if I calibrated with a SPL that does not mean that they are calibrated? Guess I need to rent one of the calibration discs again.
    [Edited last by Darren K Price on September 06, 2001 at 02:55 PM]
    Mark Walker likes this.
  6. Jeremy Anderson
    Nov 23, 1999
    1,049
    Well, I have no experience with the Yamaha, but like I said... I've yet to find a receiver with test tones that matched up to Avia or VE's tones. Your mileage may vary.
    I strongly recommend BUYING one of these discs (I prefer AVIA). It really makes a huge difference in the quality of your monitor and your home theater, and you'll find you use it to tweak stuff here and there.
  7. Marty Neudel
    Marty Neudel Stunt Coordinator
    Mar 16, 1999
    223
    The center channel in DPL has the same frequency and dynamic range as the 2 main channnels. The separation varies (although, by Dolby specs, it shouldn't) in some decoders.
    Marty
  8. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
