Downward or forward firing sub?
Discussion in 'Speakers' started by David Barteaux, Feb 1, 2004.
  1. David Barteaux
    David Barteaux Stunt Coordinator
    Jan 6, 2001
    179
    I am curious which sub would be best for a small basement theater 14x19x7.5 on carpeted cement floor?
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    That is an insignificant variable compared to the quality of the design. Most would say it makes no difference anyway.
    What is your budget?
  3. David Barteaux
    Jan 6, 2001
    179
    I would suggest that room response is very important. I was curious as to which design would provide the best results on concrete if any.
  4. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    You can't say one design is or proven to be favorable to another for concrete or really any other environment for that matter. It would depend on the sub quality itself not if it's down or front firing.
  5. AaronJB
    AaronJB Second Unit
    Nov 2, 1998
    460
    Personally, I've had downward and front firing and I prefer downward. In my small listening space, the downward firing seems to provide a wider dispersion and be less "noticable" or "speaker-specific". But that's just me.
  6. Eric Eash
    Eric Eash Second Unit
    Aug 3, 2003
    367
    depending on what you have your crossover set at, it shouldn't matter how you have your sub arranged since anything below 80Hz is non-directional. neither type is better. pick what is best for you.
    eric
  7. Bob K
    Bob K Stunt Coordinator
    Dec 29, 2003
    94
    I wound up making a downfiring sub, but the reasons were practical. I figured that a downfiring driver was less likely to get jabbed by inquiring little fingers or bashed by an errant vacuum cleaner.
    Tempest Construction Pix: http://www.audiocircle.com/circles/m...view_album.php
  8. cabreau
    cabreau Second Unit
    Dec 1, 2003
    322
    That is a beautiful, beautiful sub, Bob K. Did you have some sort of instruction manual for that?
  9. Bob K
    Dec 29, 2003
    94
    You're very kind, Cabreau.
    I built the sub pretty much straight off the Adire web site -- it's the "mid-Q" sealed Tempest design, with an AVA 250W amp. I did double up the top and bottom (the bottom being the driver baffle) so they are 1 1/2" thick.
    I have two left thumbs. If I can build a sub, anyone can!
  10. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    The problem is having the tools.
    Looks like Norm Abram from the New Yankee Workshop in there [​IMG]
  11. dave alan
    dave alan Second Unit
    Aug 30, 2002
    256
    Some prefer a front firing sub because the direct-radiated wave is the first to arrive at your ear, and all reflected sound arrives later. A DF sub will send ONLY reflected sound to your ear.
    Most prefer a DF sub because the driver is protected (mentioned above) and not visible (WAF). There is also a dB or 2 of gain associated with the compression realized from the space between the floor, or a baseplate, and the driver (depending on the engineering of that space).
    You can also make the argument that a DF sub is less localizeable (depending on the selected filter corner), because the higher freqs that your ear uses to pinpoint the direction of the sound's origin don't turn bends. This is true, but a kind of twisted logic. For a sub to 'blend seamlessly', all of the freqs fed to it through a LP filter should be heard.
    Unfortunately, the HT sub game has evolved into a 'loud beats accurate' numbers game. I'm fine with that, but I certainly cringe when people claim to have both when, in most cases, it just ain't so.
