Downfiring subwoofer on carpet floor
Discussion in 'Home Theater Projects' started by Timba, Aug 8, 2003.
  1. Timba
    Timba Auditioning
    Aug 5, 2003
    7
    I am about to start building a downfiring subwoofer using a 140L vented cabinet with ShivaIII. Should I mount the subwoofer to a base board or is the carpeted floor acceptable? Thanks in advance.
  2. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    Either way you go, I'd use spikes.
  3. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    How would spikes help if the subs downfiring?
  4. Jonathan T
    Jonathan T Second Unit
    Nov 6, 2002
    360
    Spikes transfer the least amount of vibration to the floor and walls. You don't want your whole house vibrating to the beat of your music, do you?
