Down firing vs. Front firing subwoofers
Discussion in 'Speakers' started by Sean_P_O'Brien, Nov 19, 2003.
  1. Sean_P_O'Brien
    Nov 18, 2003
    39
    Any thoughts on what is better?
  2. JamesCB
    JamesCB Second Unit
    Feb 20, 2003
    440
    It's all in the design. A well designed sub, be it front or down firing, will yield similar results. Bass (below about 80hz) is non-directional, so the orientation of the driver really makes no difference.
  3. larry mac
    larry mac Stunt Coordinator
    Aug 12, 1999
    171
    I like to take the grill off a new sub and see what it's (the speaker) doing. Plus I just like the traditional speaker look of front firing.
    If you've ever had a speaker torn to shreds by a toddler however, you might consider a down-firing one.
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    See, nobody has ever addressed my question regarding this. [​IMG]
    I take a look at a downfiring sub, and I see radial symettry as far as the driver and gravity goes. I take a look at a forward firing sub, but I never see, for example, any difference in the rubber/butyl/whatever surround material between the bottom of the driver and the top. Logic tells me that gravity will eventually affect the surround differently between the top and bottom of the driver. ??
  5. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    Not all drivers are made for a down firing application, but one would assume that if it was offered in a consumer sub, it would have already been factored in. If you are going the DIY route, Adire Audio has a formula which will let you know if a particular driver can handle a down firing configuration.
    The link is http://www.adireaudio.com/tech_paper...rientation.htm
    As for performance difference, I doubt there would be one since technically bass waves are so large they will bend around anything in their way(such as the floor), although the affects of gravity could take its toll over a period of years. No one has studied the affect over a longer amount of time as far as I know though. I guess you could ask some sonosub owners in about 5 or 6 years. [​IMG]
    DJ
  6. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
  7. Kevin C Brown
    Aug 3, 2000
    5,712
    Because the driver/magnet/voice coil assembly for a sub is usually a lot bigger, and hence a lot heavier than for a floorstander. Name a floorstander that has a 15" driver? [​IMG]
  8. TanT
    TanT Stunt Coordinator
    Dec 17, 2002
    135
    Kevin: I could name at least 10 floorstanders that has 15" in them: Klipsch, AR, DefTech, MTX, DMC, Cerwin Vega, VMPS... just to name a few [​IMG]
  9. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
    I do not think there would be any dramatic performance difference between a down-firing subwoofer and a front-firing one. The ease of placement will probably be the primary difference. With a down-firing subwoofer, you just move it around until you get the best response. With the front-firing sub however, I figure you will also have to experiment with the orientation of the sub at each position. Correct me if I am wrong. :b
  10. John Robert
    John Robert Stunt Coordinator
    Sep 6, 2003
    193
    Hsu is switching to down firing for both the new VTF-3MK2 and the new STF series...
  11. Mark gas
    Mark gas Second Unit
    Mar 23, 2002
    322
    My floorstander has a 18 inch driver.
  12. Mike Dzurko
    Mike Dzurko Stunt Coordinator
    Apr 11, 2000
    78
    At very low frequencies it makes little difference. It is more a matter of design execution than one method being better than another.
    One advantage of a downfiring sub is that upper harmonics (distortion) are more directional in nature. By downfiring, these harmonics aren't heard as easily as if the sub were front firing.
  13. DaleBesh
    DaleBesh Stunt Coordinator
    Oct 26, 2002
    163
    Designer's choice. I have never seen any numbers to say one is superior than another. They are both means to an end. I think whether a down-firing sub is sitting on a slab floor vs. wood may make some diffference on how the bass is coupled to the room.
    Assuming the sub is properly evaluated and tested, gravity has been taken into account. With a relatively light cone, good surround, and a powerful motor, a sufficient 'working distance' for the voice coil, it should be a negligible factor even over time.
  14. zangler
    zangler Extra
    Apr 16, 2003
    21
    lol....forgot B&W....hehe
  15. Tim Ranger
    Tim Ranger Stunt Coordinator
    Oct 22, 2002
    131
    Mike Dzurko
    [email protected]
    www.audioc.com
    Come on Mike, what the heck kind of marketing is that? You build great downfiring subs. Why not do the usual designer thing and make it sound like you invented it and it's the ONLY way to do things? [​IMG]
