Ryan Tsang
- Sep 23, 2000
My understanding is that you double clutch when you downshift to match revs so as to not jerk the car and reduce wear and tear. Can someone outline the procedure because I'm thinking it is not necessary. I mean, why can't you just press the clutch down ONCE, shift gear while stabbing the throttle, then let go of the clutch (release) when the revs are right. I don't see the "double."
